Forums >> Revit Building >> Technical Support >> Filled Region in Family?
Fri, May 22, 2009 at 8:02:46 AM | Filled Region in Family?
bert
Hi,
As we're creating a bunch of families, we often model the item as it appears, but show a symbol in plan. I was just wondering why there's no option to do a Filled Region within a family. I'm trying to create a black field in my symbol, and so far, the only two options we've thought of are as follows:
- a thin Solid Form with a black material; the only negative is that even though you can hide it in elevation views, it will always show in 3D.
- place a gazilion lines closely together (for instance 3/128"Winking to create the illusion of a solid; the negative there is that you create so many lines that the family becomes unnecessarily big.
Is there a better way? Thanks for reading.
Edited on: Fri, May 22, 2009 at 8:03:27 AM
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Fri, May 22, 2009 at 8:32:07 AM | Filled Region in Family?
You can only do masking regions in 3d families. But ...
Create a new detailed component that does have a filled region - load that into this family.
Edited on: Fri, May 22, 2009 at 8:33:01 AM
Fri, May 22, 2009 at 8:41:15 AM | Filled Region in Family?
Mattman2248
Mattman2248 Avatar
bert,
I have found that if you create a detail component family and make a filled region with the proper dimensions and reference planes, you can load that filled region into your family. From there you can assign the dimensions of that filled region to the dimensions of your family and from there lock your filled region to the planes in your family and then you have a paramatric filled region with your family.  Clear as mud?
Revit was once a 5 letter swear word for me....
Tue, May 26, 2009 at 7:36:46 AM | Filled Region in Family?
bert
Thanks Hub & Mattman; sounds like a good solution for what I need.
using RAC-2013
Need Family w/ scaled Filled Region and Label
Fri, Oct 25, 2013 at 6:44:04 AM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Filled Region in 3D Plumbing Family
Tue, Jun 12, 2012 at 9:06:04 AM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
FILLED REGION IN 3D VIEW OR PERSPECTIVE VIEW
Wed, Jan 26, 2011 at 5:10:05 PM
Page generation time: 0.8361
