Forums >> Community >> Newbies >> Independent Views
Fri, May 22, 2009 at 5:18:19 AM | Independent Views
triskelion
Is there any way I could make a duplicate view independent of the original view so that whenever I would make, edit or introduce anything to the duplicate view, it would not be reflected on the original view? Please help. Thanks.
"PRIMUM NIL NOCERE.........Man is brother unto man"
Fri, May 22, 2009 at 5:49:58 AM | Independent Views
4 Stars: 205 Votes
Did you check in your HELP menu?? when you duplicate the view you have several options but if you create that new view by "Dependent" then with the right button of the mouse, click and you gonna see one option for what do you want.... Now, are you see it???
Sun, May 24, 2009 at 9:09:46 PM | Independent Views
triskelion
Yes, Sir Typhoon, done those options in duplicating views. and the last one
Sun, May 24, 2009 at 9:32:21 PM | Independent Views
triskelion
Yes, Sir Typhoon, done those options in duplicating views. and the last one being converted to independent view. Still, all changes made to the primary view were also reflected on the duplicated viiews even on the converted independent view. Sir, what I would like to do is to make a similar copy, say Second Floor Plan, but that all or any introduction or change that would be made to the similar copy would not be reflected on the primary (original) view. Thanks.
Mon, May 25, 2009 at 5:20:18 AM | Independent Views
4 Stars: 205 Votes
And what do you want to Apply/Change in the model??? only text, tags, keynotes? OR walls, doors, roofs, slabs....??
Mon, May 25, 2009 at 11:51:24 PM | Independent Views
triskelion
Nothing much Sir, but as an independent view of a Structural Framing Plan of the duplicated view and to add thereon the corresponding text which in effect should not affect or update the original view.
Tue, May 26, 2009 at 3:38:56 AM | Independent Views
4 Stars: 205 Votes
When you create a Duplicate view and turn in a "Independent view" All text, keynotes... you create in that view don't appear in the original view...
Tue, May 26, 2009 at 11:14:05 PM | Independent Views
triskelion
Thanks Sir Typhoon.
Fri, Apr 9, 2010 at 11:08:19 AM | Independent Views
rolim
Hi , still got  a question , i know i probably should have done this by crating diferent phases, but the thing is , i built a model for a client and i wanted to put different  3D views on the sheet showing 1-structure and the other with the complete model , since i didn't create phases i simply created independent 3d views and simply hid the obejcts i didn't wanna see. my problem is: i got to export the sheet to DWF , and when i do this all hidden objects show up in the sheet , and i can't delete them in one view cause even tough they are independent views the objects are deleted in the other , any toughts anyone? thanks
Fri, Apr 9, 2010 at 11:12:43 AM | Independent Views
If you truely hide in view, the element will not print or export to a 2D DWF view.  Are you sure you just didn't use the sun-glasses?  That is only a temporary hide.  To hide in view, you need to select the object and right click then pick hide in view.
Fri, Apr 9, 2010 at 11:17:10 AM | Independent Views
rolim
Nop didn't use the glasses  i'll give it another go
dependent views with independent VG control
Wed, Sep 30, 2015 at 3:59:28 PM
independent view range
Wed, Dec 22, 2010 at 7:32:10 PM
Independent Investment Planning
Wed, Jan 28, 2026 at 7:05:22 AM
Matchlines and Duplicate Dependent Views
Thu, Nov 29, 2007 at 8:01:42 AM
Error Converting Dependent View to Independent View RAC 2009
Fri, Oct 3, 2008 at 8:53:23 AM
Page generation time: 1.0046
