10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Lighting fixtures that do not select with drag box selection
I have lighting fixtures in a project that will not select when I drag a box around them, but will select individually. I do not have design options or any other special treatment for these instances. Does anyone know what the problem is?
If you can select individually by pointing then for some reason, the family is probably built larger than what you see and you don't have the whole family in your window. Window a larger area and see what happens. Could also be part of a group.
Selection Box Doesn't Include Ceilings |
Tue, Jan 8, 2013 at 3:51:20 PM
How to show lighting fixtures on floor plan |
Mon, Nov 6, 2006 at 10:15:38 PM
create a new lighting fixtures |
Fri, Aug 15, 2008 at 10:54:54 AM
Copy/Monitor - Lighting Fixtures |
Thu, Dec 15, 2011 at 4:27:11 PM
Lighting Fixtures |
Thu, Apr 24, 2014 at 6:13:26 AM
