17 Users Online (15 Members):
Forums >> Revit Structure >> Technical Support >> Spot Elevation in Drafting View
10 Posts No Rating |
Hey everyone... I need to put a dummy spot elevation in a drafting view. How would you suggest going about this?
Use a dummy spot elevation symbol.
So, is there a setting to make an elevation tag a "dummy" tag rather than a regular spot elevation? I have a family called "Elevation Tag Dummy Left.rfa"... but it is only accessible to the spot elevation command...
It sounds like you have a smart spot elevation tag that you gave a dummy name .... sorry - that's not a dumb tag. This is simple - look at what commands are ghosted and what isn't. If it's ghosted, you can't use it! Spot elevations are ghosted. You have to have a dumb annotation that you can fill in.
Spot Elevation without Target |
Fri, Mar 20, 2009 at 4:57:55 PM
Spot Elevation vs. Level elevation |
Tue, Aug 19, 2025 at 1:06:15 AM
One elevation tag / two pointer directions / one drafting view |
Wed, Dec 18, 2013 at 8:58:33 AM
spot elevation orientation in 3D view |
Tue, Aug 17, 2010 at 4:25:52 PM
Spot elevation tag issue |
Mon, Jun 3, 2019 at 3:18:37 PM
