Forums >> General Discussion >> Wishlist >> BOP Tag for 2nd floor and above
Wed, May 20, 2009 at 10:03:04 AM | BOP Tag for 2nd floor and above
Relges
I am relatively new to Revit MEP and can't imagine that I am the first one to encounter this problem.
I couldn't find a Bottom Of Pipe tag, so I edited the Invert Elevation tag to be a BOP tag.  It worked great (on the first floor).  When I use it on the second floor it displays the elevation from 0'-0" not the elevation from the level from which the pipe was created.
The BOD tag works fine on all floors, why isn't there a BOP tag that works the same way ... or am I just not finding one?
What has anyone done in this situation?
Thank you in advance,
Relges
BOP Tags for 2nd floor and above
Thu, May 21, 2009 at 4:28:57 PM
BOP Relative to Sloped Soffit Above
Mon, Jan 5, 2015 at 7:38:53 AM
Doors and windows do not show up on the 2nd floor
Sun, Nov 25, 2012 at 12:23:18 PM
Visibility of 2nd Floor in REVIT 2011
Sun, Nov 21, 2010 at 8:51:10 PM
2nd Floor View Range
Sat, May 29, 2004 at 5:10:04 PM
Page generation time: 1.2938
