15 Users Online (12 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how to do an overpass/bridge
Mon, May 18, 2009 at 3:19:23 PM | how to do an overpass/bridge
simskey
what is the best way to do an overpass?
 i can think of 3 ways...
1.  columns with roof (roof being the overpass)
2.  ramp
3.  topography
 i tried it as topography which worked great except it is solid underneath instead of being open.  anyway to solve this?
 thanks.
Mon, May 18, 2009 at 3:31:05 PM | how to do an overpass/bridge
tim123
4 Stars: 19 Votes
Floor.
You just set the floor to the level that you want and you can create the structure and railings, and change levels.  If its realy complicated you can model the components separately.
Mon, May 18, 2009 at 4:00:17 PM | how to do an overpass/bridge
simskey
thanks for replying.
is this the best way to do even if the road is sloping...going over another road?
do floors slope in multiple directions?
thanks again.
Mon, May 18, 2009 at 4:47:50 PM | how to do an overpass/bridge
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I would create a generic model family, make it flexible. Families are light geometry and make your model easier to manage.
Or you could do roof my extrusion.
Mon, May 18, 2009 at 5:29:47 PM | how to do an overpass/bridge
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I have done a number of curb gutter and sidewalks using the sweep blend tool. You can do vertical curve and horizontal curve but cannot mix in Revit 2009, I have not shifted to Revit 2010 yet but believe it may be possible to do vertical and horizontal in the same extrusion. See attached PDF for some guide lines. You must name the work planes in order to have the framing elevations attach to them.
Mon, May 18, 2009 at 5:42:47 PM | how to do an overpass/bridge
alabaster2513
3.5 Stars: 25 Votes
thats pretty slick steve, doesnt all that in place modeling make your site file enormous though?
Tue, May 19, 2009 at 4:00:03 AM | how to do an overpass/bridge
tim123
4 Stars: 19 Votes
Steves method looks good.
I would suggest that you also look at the floor option.  You can slope the floor in any direction and multiple directions by using the edit sub-region functions.  Here you can set in the floor levels at different points.  I have used this method to create a bridge overpass before and it worked quite well.
Tue, May 19, 2009 at 10:54:08 AM | how to do an overpass/bridge
simskey
thanks everyone so much for responding.
i ended up using a combination of extruded roof and roof by footprint.  not perfect because it can't slope in 2 directions (vert. & horiz.) at the same time, but sufficient enough for now.  this did work well in that i could apply a guardrail as a roof fascia sweep.
Tue, May 19, 2009 at 11:50:07 AM | how to do an overpass/bridge
alabaster2513
3.5 Stars: 25 Votes
nice! Tim you just gave me an idea!
Ok add this to the wish list... edit sub region - add this function to Pads
BRIDGE
Fri, Apr 30, 2010 at 9:47:31 AM
Bridge
Tue, Oct 14, 2008 at 1:32:04 PM
2 offices connected by a sky bridge
Mon, Mar 31, 2014 at 7:55:44 AM
How does BIM combine 4D and 5D planning in bridge and tunnel projects?
Thu, Dec 4, 2025 at 7:24:21 AM
Is linking 2 revit files the best solution to split a building in half?
Wed, Mar 3, 2010 at 3:37:32 PM
Page generation time: 9.1725
