Forums >> Revit Structure >> Technical Support >> Visibility in Plan/Section Views
Mon, May 18, 2009 at 3:14:17 PM | Visibility in Plan/Section Views
breyrw
I have a family that I created for a project that is showing up like I need it to in plan and section views.  The family is a structural column family created with a revolve and has a material applied to it.
In the image, Plan-Wireframe, the two connectors can be seen in plan (concentric circles), the section marker can also be seen cutting the right connector and ending through the left connector.  When viewed with a hidden line style neither of the connectors are visible.  The view range is set to be 1 foot above and 2 feet below the level of the plan view.  The cut plan is 1" below the level, so they should be cut by the plane, but they are not showing up.  When I go to the section view that cuts the two connectors, only the right connector shows up, the left connector will show partially if I hover over it with the cursor.  If I change the left connector to a default column family it becomes visible in the section view and plan view.
Is there something I missed when I created my family?  I need both connectors to show up in the plan and section views.  Thanks for your help.
Mon, May 18, 2009 at 6:03:44 PM | Visibility in Plan/Section Views
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
check your VG, make sure that the particular items are turned on in each view. Maybe you need to make a void space in the concrete to allow it to show better.
Mon, May 18, 2009 at 8:04:39 PM | Visibility in Plan/Section Views
breyrw
The column family is set to display in VG.  I had that same thought about removing the concrete from where I am placing the connector, but another column family will show through just fine.
Tue, May 19, 2009 at 10:31:37 AM | Visibility in Plan/Section Views
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Are you using Revit Structure?
Tue, May 19, 2009 at 10:36:19 AM | Visibility in Plan/Section Views
breyrw
Yes, Structure 2009.
Tue, May 19, 2009 at 3:54:16 PM | Visibility in Plan/Section Views
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I don't want to sound stupid, I assume that you know there are two types of columns. Real Structural Columns and Architectural Columns, I had a little run in with this.
Building section callout visibility in intersecting views
Mon, Jun 16, 2008 at 12:40:58 PM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Linked Structural model not visible is certain rotated section views
Tue, Dec 22, 2015 at 2:27:12 PM
11
Building Section callout not showing in plan views
Fri, Mar 11, 2016 at 3:41:54 PM
callout annotation in section w/ coresponding section anno in plan
Mon, Sep 24, 2007 at 1:33:19 PM
Page generation time: 0.6455
