14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Simple dynamic window
13 Posts No Rating |
Hi I'm a architet who normaly model in Sketchup. I find Revit interesting and would like to start sketching in this program, and then later move the model to Sketchup to make adjustments and render in VRay. What I miss, is a very simple window, where the frame is 50mmx120mm, and the glass with only one face, it increases rendertime a lot, if it's 3d. And I would like to be able to click on the window and pull the width and height by using the mouse. Does anyone know if it's possible and can someone help ? Thanks in advance :-) Jorgensen
Windows are manipulated in the properties dialog boxes. Part of workin in Revit is creating families that fit the type of work you do. Once you commit to using this software you will find you can get it to do some powerful rendering. Most use Revit exclusively from dd to cd to rendering. Rendering time is an issue with larger files, but the quality is very good.
Storefront Window Panel Dynamic Length? |
Fri, Jun 30, 2006 at 1:43:15 PM
Simple Dynamic Family |
Fri, Nov 21, 2014 at 12:13:15 PM
Dynamic Annotations (detail callouts) |
Fri, Jul 21, 2017 at 6:11:20 AM
Dynamic View problems |
Fri, Oct 13, 2006 at 7:16:09 PM
Dynamic Weld |
Mon, Feb 24, 2014 at 7:24:16 AM
