Forums >> Revit Building >> Technical Support >> Arch problems
Mon, Jul 18, 2005 at 2:15:18 PM | Arch problems
Surfrusty
I've attached files showing an arch in plan, section and elevation. I can't seem to find a way to accurately model this. I can model a simple arch but not one with the bevel. Any ideas? Thanks!
Mon, Jul 18, 2005 at 4:21:59 PM | RE: Arch problems
TomDorner
4.5 Stars: 25 Votes
Just apply a void sweep with the proper profile to cut the wall. See the attached file as an example. HTH Tom
Mon, Jul 18, 2005 at 5:21:59 PM | RE:
Surfrusty
HTH
Tom
How did you do that?
I know I'm a newb!
thanks for the help!
Mon, Jul 18, 2005 at 7:15:20 PM | RE: Arch problems
TomDorner
4.5 Stars: 25 Votes
I took the cheaters way out to do this one. 1. Edit the wall profile to create the arch opening. 2.Go to "modelling" "create" choose doors, name the thing, choose "void form" from the left menu, then "void sweep" switch to elevation view, pick the plane of the wall, sketch 2D path (or pick path), finish path, sketch sweep profile (plan view would work), make sure you cut the wall with the void sweep (cut geometry tool) finish and finish. A more complex approach would be to build a family with the doors and void sweep all in one. Not for a newbie though. HTH Tom
Tue, Jul 19, 2005 at 11:52:31 AM | RE: Arch problems
Surfrusty
Thanks man, that worked great! Surfrusty
Problems Copying Walls from Linked Arch Plans?
Wed, Jul 15, 2009 at 4:23:32 PM
Hello All! Moving Revit Arch Drawing to Revit Structure Problems
Thu, Feb 12, 2009 at 8:18:59 AM
Adobe PDF problems
Thu, Apr 11, 2019 at 7:24:12 AM
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
When I import REV. ARCH Link, it lands way outside my work space
Fri, Oct 9, 2009 at 12:22:40 PM
Page generation time: 0.1683
