Forums >> Revit Structure >> Technical Support >> Grid Lines on an Angle - With Dimensions??
Sun, May 17, 2009 at 12:57:10 AM | Grid Lines on an Angle - With Dimensions??
SeanE
SeanE Avatar
All -
 I have a plan of a building that has a normal portion (with N/S-E/W walls) and one section that runs 45 degrees from it.  I want a horizontal grid on all of it - and then vertical grids in two places for each of the sections: at 45 degrees for one area and 90 degrees for the other.
 I can put in the grids at angle OK - but the dimensioning won't read the angled measurement....
 Any ideas??
 Thanks,
SeanE
Sun, May 17, 2009 at 1:31:41 AM | Grid Lines on an Angle - With Dimensions??
SeanE
SeanE Avatar
Never mind, I just figured it out...
 for the dimensions - the grids have to be parallel...
for the grids to be parallel, you have the little visual indicators on the lines (the little -green?- dashes that appear).
 Thanks anyhow...
SeanE
Grid Lines & editable dimensions
Mon, Mar 30, 2009 at 6:11:38 PM
changing grid lines angle - walls are detached
Fri, Apr 20, 2007 at 6:29:43 PM
Drawing Reference Planes in 3 Dimensions?
Mon, Jun 2, 2008 at 12:07:55 PM
Grid lines moving together in different floor plans
Mon, Sep 20, 2010 at 9:10:52 PM
disappearing grid lines
Wed, Apr 19, 2006 at 5:44:48 PM
Page generation time: 2.5709
