Forums >> Revit Building >> Technical Support >> Revit Architecture 2009 "failed to initialize"
Fri, May 15, 2009 at 7:53:55 PM | Revit Architecture 2009 "failed to initialize"
WilliamAT
I am completely new to this program.RA 2009 installed OK on a Sony Vaio Laptop, but when trying to run it the error message about "failed to initialize" with error code 0xc0000005 given.However, it did install and run OK on an old Acer PC!Have removed and reinstalled on the Sony. Also cleaned the Registry. Still no success.Have tried searching with Google but not found an answer.Any suggestions as to why it starts OK on one PC and not another?Thanks,Bill
P.S. Have also posted this at Autodesk forums
Wed, May 20, 2009 at 3:08:21 PM | Revit Architecture 2009 "failed to initialize"
erland73
erland73 Avatar
4.5 Stars: 85 Votes
I found this about the issue, so hope it helps you........
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software. Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions. Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).   If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions. If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution... Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection. There are several options you can specify with this switch: /NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog. /NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog. /NOEXECUTE=ALWAYSON Enables DEP on all images. /NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.) You can read more about DEP at: http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message: Access Violation (0xC0000005 exception) CAUSE: This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Edited on: Wed, May 20, 2009 at 3:10:28 PM
Revit Architecture 2009 - cannot open file using "file: open"..any help?
Wed, Jul 28, 2010 at 2:34:26 PM
"Failed Program"
Mon, Feb 16, 2009 at 2:06:35 PM
"failed to open document"
Mon, Nov 19, 2018 at 12:44:34 AM
"Seek Failed" help!!!
Fri, Jul 27, 2007 at 3:55:46 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
Page generation time: 2.0000
