Forums >> Revit Building >> Technical Support >> Section heads keep moving when view is cropped!
Fri, May 15, 2009 at 10:06:36 AM | Section heads keep moving when view is cropped!
rachaelspangler
I edited the typical section head to look like my firm's typical casework tag.  Then I went around cutting sections in front of all the casework, in order to be able to pull the elevations.  It works like a charm, except when I create a duplicate as dependent view, and then adjust the crop region...all of these casework tags (section heads) shift out of place.  I went back to each section, and dragged the section tail into the head until it was barely visible.  This has helped a little bit, but some of the section heads are still moving.  BTW, it's not affecting the section view region at all...all the casework elevations still look fine.  Can anyone tell me why this is happening? Help!
Section heads not moving with crop box
Tue, May 22, 2012 at 3:26:47 PM
Section Heads
Sat, Jun 10, 2006 at 9:49:47 PM
Section Heads
Tue, Nov 24, 2009 at 4:51:48 PM
View Heads - callout to match section/elevation heads
Mon, Mar 23, 2009 at 3:00:21 PM
Section heads - (Revit 2010)
Mon, Nov 16, 2009 at 12:48:38 PM
Page generation time: 1.1392
