Forums >> Revit Building >> Technical Support >> Hide mesh on 3Ddwg imports
Fri, May 15, 2009 at 3:03:52 AM | Hide mesh on 3Ddwg imports
mathill
Can someone explain how to hide the mesh lines on families imported from dwg etc? eg cars
Wed, May 20, 2009 at 9:08:31 AM | Hide mesh on 3Ddwg imports
travistlo
5 Stars: 2 Votes
You need to use autocad, max, or some sort of program that allows the editing of "Edges". Within max, you need the object to be a editible mesh, then selected edges, pick the edges you need to hide, and make them invisible (or hide, or something like that, i dont remember the specifics). There is also a Autoedge feature, that will use some tolerances to clean up the edges, then you can manually clean up the rest.
I think you can do the same thing in autocad, the item just needs to be a mesh, not a solid. you can select the edges, and hide them in the properties window.
Chatting it up on gmail - travistlo.j@gmail.com
Thu, Jul 19, 2018 at 9:32:19 AM | Hide mesh on 3Ddwg imports
seychellian
"You need to use autocad, max, or some sort of program that allows the editing of Edges"
Does anyone know if you can do this in rhino?
Importing a 3D mesh model into Revit and creating the mesh to solids
Thu, Dec 15, 2016 at 9:20:20 AM
Wire Mesh Handrail
Mon, Dec 20, 2010 at 3:58:42 PM
Editting a mesh in Revit, is it possible?
Thu, May 23, 2013 at 7:42:42 PM
Wire mesh curtain wall door for wire mesh wall
Mon, Sep 17, 2012 at 2:57:36 PM
Mesh not rendering to scale???
Mon, Feb 15, 2010 at 12:43:01 PM
Page generation time: 1.1907
