Forums >> Revit Building >> Technical Support >> render bottom zero level?
Mon, Jul 18, 2005 at 2:42:00 AM | render under zero level?
mmetin
mmetin Avatar
i can't have renders under zero level....THANKS FOR HELP Post edited on 2005-07-18 04:34:30 Post edited on 2005-07-18 04:35:06
Mon, Jul 18, 2005 at 5:50:48 AM | RE: render bottom zero level?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Looks like you've got an automatic ground plane set too high in your rendering settings. Go to your rendering settings-->environment-->ground plane and adjust its level as necessary.
Mon, Jul 18, 2005 at 11:38:34 AM | RE: render bottom zero level?
JoeDrevitO
There are two places where ground planes can be set, one is by distance from x-y axis, one is by level (ie if you have a level at 0). Check out my previous post. http://www.revitcity.com/forums.php?action=viewthread&thread_id=1578
Rendering Help
Mon, Dec 5, 2005 at 2:02:07 AM
Serious Error when creating Level
Tue, Dec 16, 2008 at 5:04:05 PM
why my wall top and botom are always not accorrding to the level which I drew
Tue, May 28, 2013 at 8:52:57 AM
floor plan is not shown correct.. some parts are shown as below level
Wed, Nov 10, 2010 at 3:18:15 PM
Showing walls from the bottom of slab
Tue, Feb 9, 2010 at 10:40:40 AM
Page generation time: 1.0952
