Forums >> Revit Building >> Technical Support >> Inserted Image not visible
Thu, May 14, 2009 at 10:50:43 AM | Inserted Image not visible
formfunction
2 Stars: 4 Votes
2010
The inserted image only shows as a on outline..the actual image content is missing.  Its a jpg,. I tried using another one , didnt work .
Any ideas?
Fri, May 15, 2009 at 10:07:59 AM | Inserted Image not visible
tim123
4 Stars: 19 Votes
Des this only happen in one perticular view in the project?  Is so, recreate the view and try that.  If it happens in other views, do an audit on the project when you open it.
Fri, May 15, 2009 at 10:26:13 AM | Inserted Image not visible
Are you talking about an inage in a 2D view or a decal?  Decal are 3D images and will only show when rendered.
Can't Zoom into Inserted Image
Thu, Jul 1, 2010 at 5:06:11 AM
Locking inserted image/dwg file
Mon, Aug 29, 2011 at 9:38:25 AM
Inserted Image prints upside down
Sun, Nov 13, 2016 at 9:42:45 PM
Image inserted into 3d
Mon, Dec 10, 2012 at 2:57:50 PM
Image applied in texture editor is inserted in the middle of surface
Tue, Nov 21, 2017 at 6:38:27 PM
Page generation time: 0.2484
