25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Adjustable angle door family
2 Posts No Rating |
I've seen many examples of adjustable door families here on the site. In these examples you have the option to close a door, open it, or have it at varying degrees. The problem is, these are done in two ways that I see as inaccurate. Example 1: off/on visibility parameter for door at different positions. Example 2: 3d door extrusion is set closed but symbolic lines are adjustable by way of a parameter. However, the 3d model will never change. The symbolic lines will change in plan only. What I am wanting to do is create a real door extrusion (no symbolic or model lines) that will adjust its degree of open-ness based on an angle parameter. I've played with this for hours and can't get it to work. I continuously overconstrain the object or something else occurs. Does anyone have a door that can do this? It is possible? If so, I would really appreciate a tip in the right direction (tutorials are ok but picking apart a model that someone else has created is my best way of learning) Thanks!!
You can do it so that it works in 3d on an angle parameter. Are you you using a reference line rather than a reference plane? The geometry needs to be aligned and locked to the reference line - it's sometimes a bit tricky, but definitely doable.
2 Posts No Rating |
I've attached the rfa file that I'm using. As you can see, the reference line I am using works perfectly. But once you lock the door onto it the angle dimension will no longer work.
try.....
Nested Door Family w/ Adjustable 3D Swing Angle |
Tue, Jul 31, 2007 at 5:34:20 PM
adjustable double door |
Tue, Mar 27, 2007 at 10:23:28 AM
creat double door w/ adjustable swing |
Mon, Apr 27, 2015 at 1:30:05 PM
Family Editor: works... then doesn't! |
Fri, Sep 2, 2005 at 5:23:05 PM
Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed... |
Wed, Sep 30, 2015 at 12:28:52 PM
