Forums >> Revit Building >> Technical Support >> Constraining object to ceiling
Thu, May 14, 2009 at 9:36:34 AM | Constraining object to ceiling
lilmikepb
I am using Revit Arc. 09 and I downloaded a ceiling fan off the site. I inserted it and it keeps going to the slab for some reason. How can I change it to where everytime I insert it, it becomes attached to the ceiling?
Thanks in advanced!
Thu, May 14, 2009 at 10:24:03 AM | Constraining object to ceiling
We can't tell because we don't know what the family is.  Is it floor or ceiling hosted or not hosted at all?
Try moving it in elevation.  If that doesn't work, tell us which one it is and maybe someone can look at it.
Thu, May 14, 2009 at 1:17:54 PM | Constraining object to ceiling
lilmikepb
When you search for "ceiling fan with light," it's the first one that comes up.
Thanks
Thu, May 14, 2009 at 2:12:49 PM | Constraining object to ceiling
tim123
4 Stars: 19 Votes
The ceiling fan does not host to anything - its not a Revit family.  As suggested by WWHub you can move it in elevation, but this will have to be done manually.
Ceiling mounted light family
Tue, Feb 1, 2005 at 9:04:23 PM
2D ceiling light object
Tue, Jul 5, 2011 at 2:53:16 PM
Constraining a circle centered between two reference planes
Fri, Apr 7, 2017 at 8:22:50 AM
Constraining problems - sometimes they do, sometimes they don't
Tue, May 19, 2009 at 2:04:02 PM
Can't Select an object
Tue, Mar 16, 2010 at 2:06:59 PM
Page generation time: 1.7800
