13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> 4' - 4' Accostical Ceiling Tile - Joining Soffit horizontal wall with vetical
3 Posts No Rating |
Hey, 2 questions!! I'm trying to create a 4'x4' accostical ceiling tile for the project I'm working on. Help!!!
And your questions?
3 Posts No Rating |
Oh sry, premature post. I've figured out one of my two questions, so now I only need help with this one. How do you create a 4' x 4' ceilting tile system? I tried going down the route on changing the 2' x 2', but found the options of revising that system resulted in only being able to change the thickness and viewing attributes. I'm new at this so forgive me if I'm over looking sometihng easy,
You'll need to create a new material and set the new system to utilise that material. - Duplicate the material that the 2'x2' is using.
- Rename appropriately for the 4'x4'
- For the surface pattern, click on the ...
- Select the "Model" Pattern type radio button
- If you have a 4'x4' pattern already select that and hit okay, if not select new and create a new crosshatch with these dimensions and name it appropriately.
- OK
- OK
Ensure your new ceiling type using this new material and it will display properly in your RCP. HTH.
Regards,
Chris.
3 Posts No Rating |
Mr. Spot thank you a ton. Fast response, quality response. I know where to bring my questions from now on.! Thanks again! Aaron Davis
Ceiling soffit? |
Thu, Jul 13, 2006 at 7:11:21 PM
Roof soffit inexplicably (to me) showing up as 'beyond'. |
Mon, May 7, 2012 at 11:09:14 AM
Tile Pattern Height |
Mon, Oct 9, 2006 at 2:36:02 PM
Soffit Issues |
Fri, Jan 16, 2009 at 5:37:53 AM
13
Wall Finishes |
Fri, Dec 20, 2013 at 2:26:15 PM
