15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> RAC 2009 dimention text location
4 Posts No Rating |
Greetings: Is there a way to center dimension text automatically in line centered with the dimension line? I've been moving the text manually. Thanks for your help! JBrent
Not sure what you mean. The dimension text is centered over the center of the dimension line automatically. Your options are all set through settings / annotations / dimensions and you can read about these options in your H E L P.
4 Posts No Rating |
Hi WWHub, Thanks for the reply. I Mean this: |---------3 5/8"---------| Revit will easily do this: |________3 5/8"________| or will allow you to specify an offset above the dimension line, but seemingly won't allow me to specify a negative offset which would lower the text to be centered at the dimension line. Is that a little clearer? Thanks for your help JBrent
No this is not possible. As such I would suggest you accept this is the way it is, rather than manually changing them all each time. That would be a nightmare and significantly impede your productivity. Add it to the wishlist!
Regards,
Chris.
RAC 2009 - Text in CAD file is not plotting? |
Wed, May 27, 2009 at 9:27:50 AM
Imperial Library Location |
Wed, Feb 3, 2010 at 7:26:02 PM
Dimention rounding in different views |
Fri, Jan 9, 2009 at 6:00:01 AM
RAC 2009 Slow Down - Possible Fix |
Sun, Jun 15, 2008 at 8:20:42 AM
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ] |
Fri, Aug 8, 2008 at 6:11:21 PM
31
