20 Users Online (18 Members):
Forums >> Revit Structure >> Technical Support >> Curved Sweeps?
8 Posts No Rating |
I want to create curved lines on my wall that are similar to how a sweep works. How do I do this?
If they are a horizontal sweep, why not add them to the wall description? Easier to do there.
8 Posts No Rating |
it's a curved sweep. I've already tried making a straight sweep. How do I make a curved one?
"I want to create curved lines on my wall that are similar to how a sweep works. How do I do this?" - In what? plan view or elevation view? One curve? a couple of curves?
8 Posts No Rating |
I would like to either cut out pieces of a wall like this. Or Have parts of the wall coming out but with curves in them. How do I do this? - I dont know the view or anything
Wall sweeps in elevation are limited to either horizontal or vertical, but they will follow the curve of the wall in plan. If you are wanting the sweeps to curve in elevation, then an inplace family or a model line is going to be your best approach with the wall set as the workplane... You could also do it as a face or wall based family, but I'm imagining you are wanting to be fairly freeform with your curves so the parametrics might be difficult.
Regards,
Chris.
8 Posts No Rating |
this is what im trying to do. the curved lines in the wall are what im trying to extend out of the wall.
sweeps/reveals on curved wall |
Fri, Mar 2, 2012 at 4:25:01 AM
Sweeps and window mouldings |
Tue, Jul 31, 2012 at 1:01:54 PM
How to do a vertical reveal in a sweep in a curved wall? |
Thu, Oct 22, 2009 at 2:04:26 PM
curved surface |
Tue, Nov 6, 2018 at 7:03:42 AM
Problem connecting wall sweeps (horizontal and vertical) |
Fri, May 4, 2012 at 2:07:26 PM
