Forums >> Revit Building >> Technical Support >> Joining Roofs
Tue, May 12, 2009 at 10:09:52 AM | Joining Roofs
amyjolindgren
I am having issues joining two roofs, the error message that keeps appearing doesn't tell me what the issue is, and when I join them using th join roof command, the roofs do what I wnat them to do but it doesn't stick and I get the error message.  I have attached an image of my issue.
Wed, May 13, 2009 at 6:01:48 AM | Joining Roofs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Rather than doing them as 2 separate roof sketches and joining them those 2 parts of the roof can easily be done as a single sketch.
  1. Where you want the gable, split the line into 3 pieces.
  2. So there are break points where you currently show the valley's.
  3. Then draw two slope arrows going from the valley line to the midpoint of the middle line (for the line you've just split into 3).
  4. Select the slope arrows and set their levels and falls appropriately to match the rest of your roof.
  5. Finish Sketch
This may be a little tricky to follow without a picture, I can't remember but I may have posted something on my blog about this some time ago or at least something in the forums.  If you can't follow or find it then please let me know and I'll post a screenshot.
Regards,
Chris.
Wed, May 13, 2009 at 11:06:28 AM | Joining Roofs
amyjolindgren
I think I am going to need a visuial... I keep getting an error saying that the roof footprint can't be made, and I don't exactly know where to split the line because the far left valley is in the corner of the roof.
~Amy
Wed, May 13, 2009 at 1:15:24 PM | Joining Roofs
4 Stars: 205 Votes
Hi, see this: http://screencast.com/t/avXjjp1z
Wed, May 13, 2009 at 2:38:32 PM | Joining Roofs
amyjolindgren
Thanks so much, the video helped out a lot.
~Amy
Sun, May 17, 2009 at 8:06:15 AM | Joining Roofs
4 Stars: 205 Votes
You welcome...
Wed, Jun 13, 2012 at 5:20:06 PM | Joining Roofs
yilin1985
I'm having the same problem but can't access the video. Help! What was the solution?
Wed, Jun 13, 2012 at 7:28:44 PM | Joining Roofs
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
You give the gable its own manual slope arrows, like in the attached pic.  Slope arrows are more time-consuming than slope defining boundary lines, but more powerful.
There are breaks in the boundary which exactly match the lengths of the two slope arrows.
so break-break-break the boundary, and draw two arrows over the remaining segments.
Edited on: Wed, Jun 13, 2012 at 7:31:51 PM
Mon, Jan 21, 2013 at 7:42:56 PM | Joining Roofs
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I was able to join a hip roof to a gable roof by doing the following:
1.- choose roof by extrusion
2.- In skecth mode I skecthed the shape  and hieght of my gable roof( it is important not to have a closed loop when using the extrusion tool).  For the roof by footprint tool you must close the loop. Hopefully this step should solve your problem.
3.- Now that I created a hip roof using the "roof by footprint" tool and created a gable roof using the "roof by extrusion tool", I can now join the hip roof to the gable roof.
4.- I chose the the join the roof command, clicked on the edge of the hip roof and clicked on the edge of the gable roof.  Now both roofs are now joined. Both roofs are joined. However, I have not figured out why when I click on one roof, why both roof don't highlight as 1 whole roof.
If someone can explain to me step 4 further, I would appreciated it.
Problems joining roofs
Fri, Apr 16, 2010 at 10:52:16 AM
Joining Roofs
Wed, Apr 16, 2008 at 7:45:36 AM
joining roofs
Mon, Jan 9, 2006 at 1:20:09 PM
roofs - extra geometry after joining
Thu, Jun 25, 2015 at 10:56:03 PM
Roof Joining
Mon, Jan 21, 2013 at 7:47:21 PM
Page generation time: 1.1823
