Forums >> Revit Building >> Technical Support >> link view from one project into another?
Mon, May 11, 2009 at 4:31:14 PM | link view from one project into another?
hunterfloyd
I have a project with 2 different buildings.  I've built each building in a separate file.  The sheets will be submitted all as one set.  I would like to be able to throw a view of a building section from one model to the other and place it on a sheet.  Is there a way to do this?  I've tried inserting from file, but that only allows you to insert drafting views and sheets. for some reason the sheet with my building section on it does not show up in this list of importable views.  Any help would be greatly appreciated.  Thanks.
HuntFlo
Mon, May 11, 2009 at 4:38:27 PM | link view from one project into another?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the file you want to have the view on the sheet, create a new section in the desired location (one that matches the location of the section in the other file).
Then go to Visibility/Graphics & Overrides
Navigate to you Linked Tab
You'll see the linked building file in there, click in the options,
Change it to "By Linked View" then select the section you wish it to look the same as.
Okay out of dialog boxes.
Done.
This enables you the ability to display all the tags, dimensions etc that are in the other file that you can't tag in this file.
HTH.
Regards,
Chris.
Mon, May 11, 2009 at 4:43:10 PM | link view from one project into another?
hunterfloyd
so, i have to link the entire file?  seems like an excessive amount of memory to bring into the project for only one view on one sheet.
HuntFlo
Mon, May 11, 2009 at 4:45:22 PM | link view from one project into another?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
export the section to a dwg format that link it into a drafting view of the desired project
Mon, May 11, 2009 at 6:07:08 PM | link view from one project into another?
tim123
4 Stars: 19 Votes
Right click on the view in the browser and save it to a new file.  You can then import just that view.
Mon, May 11, 2009 at 6:12:27 PM | link view from one project into another?
hunterfloyd
I don't have that option when I right click.  It's grayed out.
HuntFlo
Tue, May 12, 2009 at 6:49:59 AM | link view from one project into another?
hunterfloyd,  Go ahead and link it.  A link is not an import and your file size will not be increased significantly.  Much easier than export and importing a CAD file.
Tue, May 12, 2009 at 4:19:51 PM | link view from one project into another?
alabaster2513
3.5 Stars: 25 Votes
how do you guys handle keynoting linked .rvt projects?
Tue, May 12, 2009 at 5:15:45 PM | link view from one project into another?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Linking a file gives no overhead to the file size (it is essentially the same as an xref).  It might take a little longer to load up purely because its opening 2 files instead of 1...
This method keeps everything automated and "smart".  If changes occur down the track you won't have to worry about redoing this multiple times.
We do keynoting in the building files themselves.  The combined/site file generally will only have overall/site plans & elevations with a couple of linked views.
Regards,
Chris.
Tue, May 12, 2009 at 6:20:10 PM | link view from one project into another?
alabaster2513
3.5 Stars: 25 Votes
I just did a test project link with keynotes becuase I swore in the past when I had linked projects in one file, when I would switch my VG to my linked view my keynote tag would show up but it would be empty. I am curious what I had done wrong on that project to have them show blank. curse now that I see that work I am very happy.
Tue, May 12, 2009 at 6:24:23 PM | link view from one project into another?
#11
alabaster2513
3.5 Stars: 25 Votes
ahhh so it works by keynote but not by sheet! I see said the blind man.
 is there a way to get them to show in the keynote legend?
Edited on: Tue, May 12, 2009 at 6:26:32 PM
Insert/Link CAD Advice
Wed, Dec 21, 2011 at 2:56:22 PM
link detail drawing from another drafting view in the same project
Wed, Oct 12, 2011 at 11:14:00 AM
Revit Link - Two visual styles displayed in one view
Mon, Nov 12, 2012 at 5:37:21 AM
CAD inserts appear in as many copies in my manage link view
Fri, May 15, 2020 at 5:17:44 PM
Link AutoCAD into drafting view
Thu, Jul 7, 2011 at 1:40:26 PM
Page generation time: 2.1051
