Forums >> Revit Building >> Technical Support >> Family conflict?
Mon, May 11, 2009 at 2:01:55 PM | Family conflict?
gerardrma
I am a newbie so please pardon my ignorance to the power of REVIT (2010).
So, I have downloaded 2 glass block files from REVITCITY both with individual file names. When I insert the first as a component into a wall it works fine. When I loaded the second it reverts to inserting the first file on my drawing; the second file is not in my components loaded drop down section. How come REVIT does not recognise my second glass block component?
thank you!
Mon, May 11, 2009 at 2:09:41 PM | Family conflict?
gerardrma
fixed it!
Mon, May 11, 2009 at 2:45:09 PM | Family conflict?
gerardrma
the second glass block family was saved to the library folder 'windows'. This does not mean it is saved to the window components section. It was insertable from components within the home tab; not the window components.
option Conflict
Tue, May 29, 2007 at 11:22:17 AM
EULA conflict?
Fri, Sep 7, 2007 at 2:35:11 AM
Revit conflict with AutoCAD dwg - element graphics display issues
Fri, Feb 14, 2014 at 10:05:51 AM
11
Reference sheet conflict!
Mon, Mar 31, 2014 at 8:26:01 AM
Problems with Shared Parameters
Wed, May 23, 2018 at 9:06:59 PM
Page generation time: 0.7846
