Forums >> Revit Building >> Technical Support >> Vertical reveals to angle wall end
Mon, May 11, 2009 at 11:10:32 AM | Vertical reveals to angle wall end
beckyl
Revit 2009:
 I am trying to angle a wall end with a simple vertical reveal. I made a profile for the reveal and inserted it into the wall - the problem is that when i try to move the reveal to the end, which is where i want the angle, Revit tells me that the "sweep position is outside of the wall"and that i should check sweep parameters -but I don't see anything in the parameters that would allow me to change this. Any help would be much appreciated.
Mon, May 11, 2009 at 11:36:00 AM | Vertical reveals to angle wall end
tim123
4 Stars: 19 Votes
You could create a void extrusion in the wall category to achieve this - cut the wall rather than add to it.
Vertical wall reveals
Fri, Jul 21, 2006 at 4:54:55 PM
Precast panels and vertical reveals
Thu, Jan 17, 2013 at 9:38:52 AM
Vertical Reveals for Running Bond Pattern
Thu, Sep 3, 2009 at 8:20:46 AM
Wall end at an angle
Mon, Apr 14, 2014 at 4:26:52 PM
Creating a wall type with vertical sweeps/reveals/??
Tue, Apr 8, 2008 at 10:25:16 AM
Page generation time: 0.6022
