Forums >> Revit Building >> Technical Support >> limiting parameter????
Sun, Jul 17, 2005 at 7:34:52 AM | limiting parameter????
emad
If I want to limit a value for paramter (for example L<3000,L>1600) so that If some one entered 4000 or 1000 for the parameter do not accept it? howww????
Mon, Jul 18, 2005 at 2:28:01 PM | RE: limiting parameter????
JoeDrevitO
Its probably easier to just tell people not to put in a value outside 1600-3000, but if you need to limit them one way I can think of is to just make revit have a computation error that wouldn't let them generate a type with those parameters. For example get it to do something with the number that would make it negative if its outside of your specified values then use sqrt to take square root (revit doesn't do complex numbers......yet). Yes all you guys, I realize this is silly and wierd, but if there's no other way and it is absolutely neccesary then you tell me a better way! (p.s. I would probably never use this myself)
Mon, Jul 18, 2005 at 3:14:12 PM | RE: limiting parameter????
TomDorner
4.5 Stars: 25 Votes
You could use a nested IF statement to limit the values to a min or max. Something along the form of: IF (Test Condition, Result if True, IF (Test Condition, Result if True, Result if False)) HTH Tom Post edited on 2005-07-18 19:19:52
Sat, Jul 23, 2005 at 10:58:48 AM | RE: limiting parameter????
emad
thanks very much this worked alot!!
Mon, Jul 18, 2005 at 4:01:55 AM
LENGTH LIMITING IF STATEMENT
Tue, Feb 24, 2009 at 7:49:23 PM
Working in Perspective View
Wed, Jun 3, 2009 at 6:23:32 AM
Limiting Elongation and Distortion In Interior Views/perspectives
Sun, Aug 8, 2010 at 9:02:44 AM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Page generation time: 0.1495
