Forums >> Revit Building >> Technical Support >> Disappearing dashed lines?
Sun, May 10, 2009 at 12:27:52 PM | Disappearing dashed lines?
claire02
I am using the line tool to draw dashed lines indicating overhead elements and up til now it has been working fine. But for some reason the dashed lines have started to appear as continuous solid lines? I cannot see what has changed and it is not an issue of scale...any ideas?
Sun, May 10, 2009 at 12:35:25 PM | Disappearing dashed lines?
claire02
Oops after days of hassle i just figured out the problem. I had offset the bottom level of my view range...once i reset this to zero the lines are showing as they should.
Tue, Feb 21, 2017 at 2:16:48 PM | Disappearing dashed lines?
cboersen
Not sure if you are still there but even years later this tip came in hand.  I am using 2017 and had the exact same thing happening and the same issue was causing it.  Thanks for coming back to post the solution.
Dashed lines in families are showing as solid lines in project
Thu, May 10, 2012 at 8:38:48 AM
dashed lines above cut plane
Fri, Jan 2, 2015 at 2:28:18 PM
Underlay as dashed lines 2012
Sun, Nov 24, 2013 at 9:26:02 PM
Make lines of walls dashed?
Tue, May 4, 2010 at 10:03:23 AM
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
Page generation time: 1.2056
