Forums >> Revit Structure >> Technical Support >> Beams and Stick Symbols
Sat, May 9, 2009 at 7:46:06 AM | Beams and Stick Symbols
galambos
Using revit structure 2009...
I am trying to make a beam family where i can add a symbolic line extension at each end to represent the beam bearing on a wall. instead of the beam symbolic line terminating at the face of the wall, the symbolic line would extend over top of the wall.
I have added an extra piece of symbolic line and locked it to the "stick symbol left" reference plane, locked a dimension on to the line and it works fine when i load it into my project.  However, when i do the exact same thing on the right side (end of beam) and load it into my project, revit tells me it cant make this beam type.
 Does anyone have a work around?
Mon, May 11, 2009 at 6:14:26 PM | Beams and Stick Symbols
mhans
3 Stars: 10 Votes
Hi,
Can you show a screenshot or a sketch? I think, since you are just trying to show a symbol, can you make one type for the right and one type for the left?
Motto: "No Post left behind"
Stick representation of beams
Tue, Mar 3, 2009 at 11:47:06 AM
Deleting import symbols
Thu, May 8, 2008 at 3:14:21 PM
Tapping in to Current Drawing Scale for Use in Formulas
Wed, Oct 28, 2009 at 3:35:14 PM
override stick view for structural members?
Sun, Jul 25, 2004 at 8:02:31 AM
symbols, detail components
Mon, Jan 23, 2012 at 6:35:40 AM
Page generation time: 0.1341
