Forums >> Revit Building >> Technical Support >> rim board
Sat, Jul 16, 2005 at 3:37:21 PM | rim board
McGraw
Hello, Newbie question here. Beam systems work great for floor joists. Is there a quick way to do the rim board on residential floor framing? TIA, Sam
Thu, Oct 19, 2006 at 4:03:39 PM | RE: rim board
inverted
i'm a newbie NOW..... i was wondering the same question..... did you find an answer to modeling rim board? josh
Thu, Oct 19, 2006 at 4:55:24 PM | RE: rim board
McGraw
You can model them as beams but the ends don’t lap. You can fuss with end extensions to close the gap. There may have been changes since this post. I resorted to a fill region in plan and detail component in section. Lately, I have been doing all my framing as view specific detail lines. HTH, Sam
Thu, Oct 19, 2006 at 5:13:07 PM | RE: rim board
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What about a host sweep-->slab edge. Would this work? I'm not all that familiar with the term rim board and I'm just going on what it sounds like Puh
Regards,
Chris.
Thu, Oct 19, 2006 at 6:17:30 PM | RE: rim board
framerman
4 Stars: 13 Votes
Ahhh I have the answer you are looking for! Mr Spot, the rim board is the outermost part of the floor framing system. I can't believe I...am telling something to Mr Spot (you are a revit god!) But to answer the question, I too had asked this question. The best way I found....and the quickest way is to create a wall the thickness of your rim joist. Attach the plywood and the siding material to it also. It will align and snap and mitre and anything you want it to do. Let me know what you think of it.
Thu, Oct 19, 2006 at 7:30:19 PM | RE: rim board
McGraw
Yes, I think the floor edge sweep is reasonable. The small wall is an interesting method, Framer Dude. Sam
floor edge rim
Thu, Jul 28, 2011 at 1:29:11 PM
Fascia Board Too Long
Tue, Nov 20, 2012 at 10:19:31 AM
Hardie Board Panels
Wed, Sep 11, 2013 at 3:44:35 PM
frieze board
Sun, Jan 8, 2006 at 11:21:01 PM
Timber External Cladding BOard / Weather Board
Wed, Mar 31, 2010 at 10:02:29 AM
Page generation time: 0.4923
