Forums >> Revit Building >> Technical Support >> Rendering Decals
Fri, May 8, 2009 at 9:07:08 AM | Rendering Decals
jecaper
I have inserted several decals in a project and I cannot get them to render.  I have included the location path in the options>rendering dialog as well as located the path and file in the decal types dialog.
I am stumped, please help
Jim
Fri, May 8, 2009 at 9:45:49 AM | Rendering Decals
tim123
4 Stars: 19 Votes
Some possible reasons are:
They are not on the correct face, or on the wrong side of the face.  You sometimes get this problem when applying decals to very thin faces, such as a picture face.  If its a thin face hide this in the view and check that the decal is not behind, hosted on the wall or surface behind.
 The face that you're trying to apply the decal to is on a split face.
The visibility settings of the decal are too bright or dull for the render settings.
Fri, May 8, 2009 at 10:48:24 AM | Rendering Decals
jecaper
tim123,
Thanks for the info. Here is my status now.
 I tried to hide the frame - no good still not visible
I tried to rotate the decal (just in case)  - no good still not visible
Here are the settings -
intensity 10
reflectivity 0%
transparency 0%
luminance - none
Should I add a bump pattern?  I don't see how this could help, but I will try anything.
Thanks again for your help.
Fri, May 8, 2009 at 10:57:30 AM | Rendering Decals
tim123
4 Stars: 19 Votes
If its a picture frame, try and place the decal on the wall next to it to check that the decal is working.  That will rule out some of the possibilities.  If it is visible then it is probably that the decal is on the wrong side of the surface.
Fri, May 8, 2009 at 11:45:11 AM | Rendering Decals
jecaper
Thanks again for your help.  As it turns out, I guess it was on the wrong side of the surface.  I removed the surface and voila there it is.
problem with rendering decals
Mon, May 14, 2007 at 5:44:57 PM
Decals not Rendering in 2010/12
Wed, Jul 20, 2011 at 1:34:53 PM
problem rendering decals
Tue, Aug 3, 2010 at 8:18:16 AM
Decals not showing..
Fri, Feb 16, 2018 at 9:39:04 AM
12
Decals not rendering
Wed, Aug 17, 2011 at 11:00:09 AM
Page generation time: 0.2626
