13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> how do you make structural beam systems visible.
14 Posts No Rating |
Hi; I created a structural system, but it is only visible in 3 D views . How do I make the system in floor plan views and elevation. I go to edit view properties and check the structural bema systems and check the hidden lines. The hidden line and structural system propertion options are hatched pretty much except for projection/surface- lines thanks
Edited on: Thu, May 7, 2009 at 4:14:07 PM
Set the view detail level to fine.
Thanks tim123; I set view properties to fine for structural beam systems, but still did not work. any other ideas thanks sudanhafif
In an elevation view set the view properties to fine. Also confirm that the depth of the elevation is sufficient to see the beams. In a plan view, check the view range. Set it to unlimited for view depth - the beams are by default created so that the top of the beams are at the level they were drawn in, so they may not be visible. If they are visible as lines, setting the detail level of the view to fine will make them visible.
Structural Beam Invisible Partial In Plan View |
Tue, Mar 20, 2018 at 4:39:48 AM
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
Beam Systems |
Wed, Aug 13, 2008 at 11:42:00 AM
Structural beam system visibilty |
Mon, Jan 28, 2008 at 6:08:26 PM
Sloped Beam Systems Q's |
Mon, Nov 14, 2016 at 11:48:46 AM
