Forums >> Revit Building >> Technical Support >> Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 3:49:41 PM | Door Tag Parameter-Need it to be the door opening number, not the door type.....
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
...................actually I used to know how to set this.  I prefer my door schedule to have each opening numbered, with the door number in the door tag, and then the schedule shows the details including the hardware set number.  I got guidance on how to do this long ago.  I am doing an addition to an older project and its door tag is set to the door type and I can't remember how to reset it to be the door opening number.  Can someone forgive my faulty memory and remind me how to do this?
Thu, May 7, 2009 at 4:09:39 PM | Door Tag Parameter-Need it to be the door opening number, not the door type.....
edit the family and change the pointer to the mark.  Or if you have a good tag in a later project, give the bad one a different name in the browser,  load the good one in the project.  Click on the old tag - select all instances and switch it to the new tag.
Door tags and Door Type ID
Wed, Jul 10, 2013 at 1:40:25 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Door Tag driven by door parameter.
Tue, Jun 28, 2011 at 12:01:00 PM
Door tag lables/parameters
Mon, Jul 10, 2006 at 1:39:50 AM
Combining Door & Window Schedule; it WORKS!
Wed, Jan 20, 2016 at 10:15:28 AM
Page generation time: 0.6648
