Forums >> Revit Building >> Technical Support >> Glass transparency when plotting
Fri, Jul 15, 2005 at 12:06:40 PM | Glass transparency when plotting
Surfrusty
I have a few interior perspectives I'm trying to plot but the glass always comes out opaque. In the view it is transparent. I even lowered the transparency to 100 and still have the same problem. Help! Surfrusty
Fri, Jul 15, 2005 at 7:41:54 PM | RE: Glass transparency when plotting
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I have no problems getting a shaded or hidden line perspective printing with glass transparency? Does the same thing occur when printing to PDF? Are you using the latest build of Revit? I tested it on Build: 20050523_2300
Mon, Jul 18, 2005 at 1:04:41 PM | RE: Glass transparency when plotting
arnosandoval
5 Stars: 3 Votes
Make sure that when you are printing, you use Raster printing instead of Vector(in your printer settings), that way the glass comes in transperant.
Mon, Jul 18, 2005 at 1:07:06 PM | RE: Glass transparency when plotting
Surfrusty
Thanks! That was the problem. I was using vector instead of raster. Surfrusty
Glass: Reflecting an Image
Mon, Aug 25, 2014 at 8:41:01 AM
Transparency of glass windows in 3d views
Wed, Aug 5, 2009 at 10:43:37 AM
curtain wall glass transparency
Tue, Apr 19, 2005 at 2:41:00 PM
Windows Transparency
Sun, May 21, 2006 at 11:43:15 PM
controlling transparency / visibility
Wed, Oct 24, 2007 at 4:59:24 PM
Page generation time: 0.4224
