Forums >> General Discussion >> Wishlist >> Railings
Thu, May 7, 2009 at 11:17:35 AM | Railings
dpohlman81390
1 Stars: 2 Votes
Revit should have more elegant modern railings. The ones that they have are so plain.
Thu, May 7, 2009 at 11:21:45 AM | Railings
Thread Post Kudo! #2
dpohlman81390
1 Stars: 2 Votes
I have a picture here of what type of railing I want. If anyone can make it for me that would be great.
Thu, May 7, 2009 at 11:23:22 AM | Railings
Thread Post Kudo! #3
What ships with Revit is a minimum.  It's up to you to create what you want.  Goto the on-line library and look at the Revit samples - There is a rvt file there with many different railings you can copy into your project.
Thu, May 7, 2009 at 11:37:09 AM | Railings
dpohlman81390
1 Stars: 2 Votes
I believe I can create but I am relatively new to the program so is there a way to set the railing design so that it follows the shape of a staircase and normal flat railings.
Thu, May 7, 2009 at 1:42:05 PM | Railings
Check out these:
http://revit-alize.blogspot.com/2005/11/stairway-to-heaven.html
http://do-u-revit.blogspot.com/search/label/Railings
RAILINGS RAILINGS?????
Wed, Oct 1, 2008 at 3:48:49 PM
Frenc h railings
Wed, Feb 18, 2009 at 2:51:56 PM
11
Problems attaching railings to stairs
Mon, Dec 2, 2013 at 10:49:14 AM
stair railings-inserting glass
Mon, Dec 9, 2013 at 11:37:40 AM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Page generation time: 0.0951
