Forums >> Revit Structure >> Technical Support >> Working with parameters...help please?
Thu, May 7, 2009 at 8:30:41 AM | Working with parameters...help please?
TyMad
Hi, I am trying to figure out how to use parameters. I know how I can set them up in a family file & make them so that they adjust different aspects of the object, but what I am having problems with is when I load my family file into my project. I don't have the option to adjust these parameters. I have family files nested inside of family files and the parameters from the files that are nested do not show up to be able to change. Is it not possible to adjust these said parameters unless you open the nested family file & change them? I tried using shared parameters but I still don't get how I can make them show up to change the dimensions in a job. Basically, I modified the pier bent detail from the Revit extensions to make a typical pier that we see in many of the bridges we inspect. The pier detail is a family file. Then inside of that family there is a bearing detail that is nested & sits on top of the pier. The bearings are setup in their family to be arrayed & have parameters for spacing & number of bearings. That family has a nested object in it as well that is just one of the bearings which has editable dimensions for the size of the bearing plate & girder plate. So is it possible to make those editable dimensions in the single bearing family to show up & be changeable in the project? Thank you
Thu, May 7, 2009 at 9:14:25 AM | Working with parameters...help please?
Read your H E L P - search  nested parameters for your answers.
Thu, May 7, 2009 at 10:02:50 AM | Working with parameters...help please?
TyMad
Thank you. Someone on AUGI Forums already told me how to do them.
Instance Parameters in titleblock not linking
Wed, Dec 28, 2011 at 10:31:23 AM
12
How to inventory used/unused parameters?
Fri, Jan 29, 2016 at 11:43:10 AM
Complete Categories and Parameters List
Wed, Sep 17, 2008 at 6:27:46 PM
Doors, Shared parameters problems
Thu, Sep 3, 2009 at 1:24:29 PM
Dimension parameters within groups / arrays
Thu, Mar 31, 2011 at 12:53:47 PM
Page generation time: 1.6070
