Forums >> Revit Building >> Technical Support >> solid concrete cone
Thu, May 7, 2009 at 5:15:40 AM | solid concrete cone
dinorik
hey there,
my building is a cone shaped concrete thing. I used solid blend to create the building. It seems like you cannot create a fully coneshaped building and use wall by face, for it cannot detect the space or something.
Anyway, my question is this: to create a full cone i want to connect a new concrete top with the rest of the building, but i haven't found a good way to create a cone so that it has the same angle and has a material added to it. Namely, concrete.
Thu, May 7, 2009 at 5:33:10 AM | solid concrete cone
tim123
4 Stars: 19 Votes
You can create the top concrete bit as a wall rather than a mass and give it a concrete material.  This can be done as a revolve in elevation to get the angle correct.
Thu, May 7, 2009 at 7:02:56 AM | solid concrete cone
Use a triangle and revolve it to get a true cone.
Thu, May 7, 2009 at 9:27:53 AM | solid concrete cone
erland73
erland73 Avatar
4.5 Stars: 85 Votes
You can load a cone from the Revit library.....
creating a cone
Mon, May 4, 2009 at 9:15:56 AM
Sloping & angled walls
Fri, Oct 1, 2004 at 4:35:15 AM
Solid Blend problems
Mon, Jul 20, 2009 at 4:04:05 AM
Solid fill and concrete hatch
Wed, Mar 28, 2012 at 3:19:54 PM
Curved / Cone style Roof
Sat, May 25, 2013 at 4:03:11 PM
Page generation time: 0.1642
