14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> Can not tag beams
im trying to tag all my columns and beams on a job i am working on and i get a message saying ''no tag is loaded for this type. would you like to load tag now'' but when i try to load the tag i cant seem to find a tag for it. i must of changed a tag family or something along them lines because i could tag them on the last job i was working on, its strange because it lets me tag foundation pads can any1 help as i have a deadline to meet. cheers
49 Posts No Rating |
Assuming that you have modified your default tags, I have attached the tags for structural column and structural frame for your use. Hope this helps.
Cundall, you have that (if you don't delete) in your "Annotation" folder in your Metric/Imperial families...
You can also edit the tag family from your previous jobs and save it to the annotation family folder.
cheers for your help, youve helped me alot
Tagging for floors between beams |
Tue, Jan 31, 2012 at 5:23:10 PM
Beam Tag with Top of Steel Elevation ? |
Fri, Aug 1, 2014 at 8:12:42 AM
length in beam tag |
Sat, May 26, 2012 at 12:25:40 AM
Beam System Tags |
Wed, Feb 27, 2013 at 12:55:27 AM
Beams at different elevations in one plan |
Mon, Nov 21, 2011 at 11:51:21 AM
