Forums >> General Discussion >> Revit Project Management >> position of materials
Wed, May 6, 2009 at 7:31:30 AM | position of materials
nkouwenberg
Hello,
I'Ve got a question, im currently making an interior scene. now i can't control the position of my wall texture, the stones are starting at the wrong position.
 is there some way to control de texture map on the wall??
Wed, May 6, 2009 at 7:46:36 AM | position of materials
If you are talking about the fill pattern, you can adjust it if it is a model fill.  Just tab over a line and you can rotate or move the pattern.  You can also use align if the pattern has straight lines in it which I assume it does.
If you are talking about render material, please read your H E L P.   There are several topics you should review using render pattern as a search including Texture Alignment.
Bricks are twisted... materials going up instead of sideways
Thu, Jul 21, 2011 at 2:30:06 PM
Aligning text position in different labels.
Fri, Sep 25, 2009 at 9:48:29 PM
Elevation detail number position
Wed, Oct 13, 2010 at 10:35:41 AM
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Missing Materials
Wed, Jun 19, 2013 at 2:22:26 PM
Page generation time: 0.2214
