Forums >> Revit Building >> Technical Support >> Mass and walls are squiggled
Tue, May 5, 2009 at 1:16:12 PM | Mass and walls are squiggled
mowyllie
Here's a new one.  I have a user who imported a CAD file that had at one point been "squiggled" for presentation purposes.  She used that CAD file to build a mass model and then used that mass model to create walls using the model's faces.  Both the mass model and the walls are showing in all views as squiglly lines.  And, to make matters worse, this issue is affecting new walls that are drawn detached from the model and nowhere near the vicinity of the model.  I am truly stumped.  Anyone know a fix for this?  I've tried deleting the walls and editing the model.  Those didn't work.  I also looked for visibility overrides and/or object style settings.  Nothing.  Aaaaack!
Tue, May 5, 2009 at 1:20:14 PM | Mass and walls are squiggled
Ah come on - suggestion - Don't do that!
What do you expect, walls by face use the mass model's face.
Tue, May 5, 2009 at 2:23:00 PM | Mass and walls are squiggled
mowyllie
While I totally agree with that, the problem I'm having now is that the issue has perpetuated itself into walls that aren't at all linked to the mass model.
walls disassociated with mass - can't update walls
Fri, Nov 2, 2012 at 10:51:18 AM
Tops of the walls applied to mass looks horrible
Mon, Jan 5, 2015 at 10:45:47 AM
How to attach top/base - walls to mass roof
Tue, Sep 22, 2015 at 3:18:05 PM
Need HELP creating walls from mass
Wed, Nov 7, 2012 at 6:35:21 AM
mass from walls- is it possible?
Fri, Nov 19, 2010 at 7:30:05 AM
Page generation time: 1.3145
