Forums >> Revit Building >> Technical Support >> Can't manipulate roof pitches?
Tue, May 5, 2009 at 9:39:38 AM | Can't manipulate roof pitches?
JSiedArchitect
JSiedArchitect Avatar
I have created the roof in the sketch below-
As shown it is 4 pieces, the geometry have not been joined.
When I try to edit the pitches on these roofs I get an error.  Roof can not be made or something similar.  What gives?
I am trying to vary the pitch front-back & side-side, but am not sure why that would make a difference.
Thu, May 7, 2009 at 2:01:25 PM | Can't manipulate roof pitches?
travistlo
5 Stars: 2 Votes
I usally get those errors when it cannot make the condition for the soffit/fascia or at the bearing plate. If you used pick walls for your roofs, try it without picking the walls, just draw the lines. You get very differnt results depending on how you create the roof.
Chatting it up on gmail - travistlo.j@gmail.com
Hip roof problem
Wed, Feb 27, 2008 at 5:28:59 PM
Roof Question
Wed, Sep 20, 2017 at 10:13:43 AM
Constraining Reference Planes to Roof Pitches
Mon, Feb 5, 2007 at 6:53:14 PM
Button that allows me to manipulate an element
Thu, Oct 16, 2014 at 8:16:47 AM
Split/manipulate roof
Mon, Jan 28, 2013 at 9:43:56 AM
Page generation time: 1.4844
