Forums >> Community >> The Studio >> Filled furniture
Tue, May 5, 2009 at 6:43:10 AM | Filled furniture
adrengifo
Hi
I am traying to make the furniture transparent, so you can only see the edge lines of the furniture and see the colour of the rooms scheme. Is there a setting to do this?
Thanks
 Alfonso
Tue, May 5, 2009 at 6:57:00 AM | Filled furniture
Note - you can set this up in your view template if you use them.
In the view - VG - check the transparent box for furniture.
Tue, May 5, 2009 at 7:05:37 AM | Filled furniture
adrengifo
Hi
Thanks for the promt reply, I tried that but everything dissapears, also i checked that the colour scheme is in the background.
Tue, May 5, 2009 at 7:12:45 AM | Filled furniture
I just tried it and it works for me.  I used a colored area plan and a stock revit desk.  You must be doing something different that you have not posted.
Thu, Jul 16, 2009 at 3:58:44 PM | Filled furniture
pepsiqueen
pepsiqueen Avatar
WWHub, i also tried that method and was not successfull. the furniture does not show up, it gets totally covered by the color.
I'd rather be riding at whistler. or highland. thats good too.
Fri, Jul 17, 2009 at 7:29:45 AM | Filled furniture
Sorry but it did work in 2008 as seen in the attached image.  At the time the question was asked, I was using 2008.  It appears not to work in 2009.  I have not checked it out in 2010.
Fri, Jul 17, 2009 at 12:06:56 PM | Filled furniture
pepsiqueen
pepsiqueen Avatar
the way i am working around this is that i select all teh furniture, appliances, generic models, stairs etc. that i want to be in color, then i do a right click and override graphics by element. I them assign them all a surface pattern (solid) and chance the color to be whatever i want.
color filled furniture problem
Wed, Jan 4, 2012 at 9:59:16 AM
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:33 PM
Difference between Furniture & Furniture Systems
Thu, Jan 4, 2007 at 2:37:47 PM
Turning off Certain Furniture
Tue, Jun 20, 2006 at 2:09:52 PM
Furniture X Furniture Systems Families Templates
Fri, Mar 17, 2006 at 6:16:18 PM
Page generation time: 1.8511
