27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Newbie trying to understand central files vs. import revit files
2 Posts No Rating |
I am a newbie to working with central files. I have received from an outside Architect a large revit file and need to add specific furniture and sign elements to the file. I am trying to find an easy solution to using central files and what are the steps I should take in using this file? Should I open the central file they sent and then re-save as a new file or should I import their central file as a revit link ? What is the best way so I do not disrupt their files but allows them to import my additions back into the central file at their site?
You need to spend some time with your H E L P. Look up worksharing first. This will lead you to explanations of central and local files. Then look up copy/monitor and linked files. The best approach here would be a copy monitor process on both ends.
Deleting local files and copying files from central |
Fri, May 23, 2008 at 11:28:55 AM
saving as non central models |
Thu, Dec 12, 2013 at 10:17:30 AM
HOW TO IMPORT 3DS files and DXF files into REVIT 2011? |
Sun, Nov 7, 2010 at 6:21:00 PM
CENTRAL FILE back-up Files |
Tue, Jan 29, 2013 at 1:26:27 PM
Linking Revit files |
Fri, Jul 22, 2005 at 6:08:10 PM
