Forums >> Revit Structure >> Technical Support >> Revit 2010 Masking Regions
Mon, May 4, 2009 at 2:14:39 PM | Revit 2010 Masking Regions
mreed
Is anybody having problems with masking regions in Revit 2010 not masking anything.  We hae a Break Line component that we use that is just a masking region and it still shows everything behind it.  I have also just drawn in a masking region, but everything still shows up.  I have sent to the front and that does not work.  We have been using this with 2009 and had no problems.
Mon, May 4, 2009 at 3:14:23 PM | Revit 2010 Masking Regions
4 Stars: 205 Votes
Nope, no problem at all....
Mon, May 4, 2009 at 3:24:51 PM | Revit 2010 Masking Regions
mreed
See attached image.  It is not masking the components.
Mon, May 4, 2009 at 11:16:58 PM | Revit 2010 Masking Regions
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi mreed, have you checked in Override--> by Element, if you don't have checked "Transparent".....
Tue, May 5, 2009 at 7:22:42 AM | Revit 2010 Masking Regions
mreed,  I must be seeing something other than what you are talking about.  I see two break line symbols, whaich if they are revit standard, they include masking rgions and appear to work.  If the circle is supposed to be a masking region, then you have done something else.
Tue, May 5, 2009 at 8:09:08 AM | Revit 2010 Masking Regions
mreed
The two cut lines appear to work because I have stopped the lines at the break to make it look correct.  The circle is a masking region that does not mask.  I did check the overrides as suggested and they are not set to transparent.
Tue, May 5, 2009 at 10:54:04 PM | Revit 2010 Masking Regions
qthdad
5 Stars: 2 Votes
Make sure you are in Hidden Line mode and not wireframe.
Mon, Nov 30, 2009 at 4:42:34 PM | Revit 2010 Masking Regions
rltaylor3
rltaylor3 Avatar
Hidden Line mode! Thank you! ...duh
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Exporting to Autocad with Masking Regions
Thu, Apr 25, 2013 at 10:33:27 AM
11
Masking Regions not "masking"
Mon, Dec 14, 2009 at 11:21:22 PM
masking regions
Mon, May 11, 2009 at 4:31:49 PM
Masking Regions
Wed, Nov 14, 2007 at 10:07:16 AM
Page generation time: 4.5764
