Forums >> Revit Systems >> Technical Support >> Drawing Notes
Mon, May 4, 2009 at 1:19:50 PM | Drawing Notes
koolair
4.5 Stars: 2 Votes
Hi everyone,
I would like to issue a drawing for coordination to several consultants.
I identify a duct size on my drawing, but want to add a note.  I first use the duct size tag, which automatically detects the size of duct and updates as I change the size.
The note in its entirety should read as follows:
1200x600 U/G HVAC
DUCT SHALL BE LINED
WITH INSULATION
However, the duct tag will not allow me to append a note.
So I used the duct tag, then added a text box under it, but now the note looks like this:
1200x600
U/G HVAC DUCT SHALL BE
LINED WITH INSULATION
I hope you guys follow what I mean.  I want the words to immediately follow the 1200x600 and all together form one text box.
Cheers!
Mon, May 4, 2009 at 4:16:50 PM | Drawing Notes
Edit your tag family and add instance based text
Tue, May 5, 2009 at 2:37:42 PM | Drawing Notes
koolair
4.5 Stars: 2 Votes
awesome.  Thanks!
Fri, May 8, 2009 at 8:39:39 AM | Instance based text
koolair
4.5 Stars: 2 Votes
Hi, thanks for that last reply.  Can you please give me an idea as to how I would add instance based text to a tag?  If it's complicated to explain, maybe you have a link?
Thanks again
Fri, May 8, 2009 at 8:54:56 AM | Instance based text
koolair
4.5 Stars: 2 Votes
Thanks again
Best Practice for standard notes within drawings
Thu, Dec 10, 2009 at 10:39:36 AM
Production Text Notes - Global Visibility
Wed, Mar 8, 2017 at 1:43:55 PM
Legends? Schedules? Annotation Notes?
Mon, May 18, 2009 at 5:05:31 PM
sharing notes with other projects
Sat, Dec 29, 2007 at 3:25:56 PM
Multiple Sets of Keyed Notes
Tue, Dec 14, 2010 at 7:11:26 AM
Page generation time: 1.3971
