10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> leader segment problem
9 Posts No Rating |
I have my text notes with 2-segment leaders: first segment with angle and second segment flat. The problem is for some of the text notes, the flat second segment always changes to the same angle of the first segment so they become one straight line. Does anybody know how this happens?
9 Posts No Rating |
If you adjust notes after placement, you sometimes you have to adjust the leaders as well. Just grab the node and adjust the leader back into a double.
9 Posts No Rating |
"If you adjust notes after placement, you sometimes you have to adjust the leaders as well. Just grab the node and adjust the leader back into a double." I have been adjusting the nods all the time and they kept changing back.
split segment on detail view |
Tue, Nov 20, 2007 at 12:55:02 PM
Using spit segment when cutting a detail on plan |
Wed, May 10, 2006 at 9:17:10 AM
Elevation Tag - Leader Problem |
Thu, May 17, 2012 at 5:48:20 PM
Curtai Grid - Add/Remove segment |
Sun, Sep 7, 2014 at 9:34:13 AM
12
ARC LEADER NO TEXT |
Thu, May 2, 2013 at 10:36:04 AM
