Forums >> Revit Building >> Technical Support >> Autocad Import Problems
Mon, May 4, 2009 at 12:10:53 PM | Autocad Import Problems
fmunoz
I usually dont have any problems importing Autocad files into Revit, but every once in a while I import a file that seems to have something about 5,000' away from the drawing because i get a huge outline on the DWG. But when I go the Autocad i cant find anything and a zoom to all only shows the drawing and nothing else in space. I have tried everything i can think of from changing the proxygraphics, setting the Autocad drawing to be closer to 0,0, setting up the paper space to have only the extents of the drawing, taking out the paper space so it imports the model space. I found out that one of the files it always does it on is when it the Autocad drawing was made in my Autocad template so i have tried selecting just what I want to import and putting it into a blank autocad but that hasnt worked either. Is there a Autocad setting or Revit setting that I am not thinking about or have missed?? This isnt that much of a problem when i import to floor plan because i can crop out the rest of the view. But its a big problem when I import to draftin view. The one I'm currently working on is some general notes and views that i put on my general sheets. I dont want to explode the autocad in Revit because i use 3 different sheet sizes and I will need to be able to scale the autocad depending on the sheet size i use.
Mon, May 4, 2009 at 12:41:08 PM | Autocad Import Problems
4 Stars: 205 Votes
Did you try in Autocad to see if you have (in 3D view) some objects with wrong elevation, imagin, you have almost the project in elevation 730.00m but some objects in elevation 0.00m????
Mon, May 4, 2009 at 12:51:18 PM | Autocad Import Problems
fmunoz
i have tried 3D view in some files and i have found some objects but theres other files that i have not found anything in 3D view. I never really used Autocad in 3D so i find it rather difficult to use so it might be that i just dont know where to look
Mon, May 4, 2009 at 12:56:07 PM | Autocad Import Problems
4 Stars: 205 Votes
Can you put here one of those files so i can take a look???
Tue, May 5, 2009 at 1:42:02 PM | Autocad Import Problems
fmunoz
I've been playing around with the Autocad, I put it in 3D and did a zoom to all and got the same zoom back like in Revit. I started deleting objects til it only zoomed to the drawing, it turned out that it was Attributes that were making it zoom far away. After I deleted the Attributes the zoom in 3D was correct so thought it was going to work in Revit but I got the exact problem again. I would put up the file but unfortunately i didnt create it and the creator doesnt want his file up, it has a lot of his general info that he has worked hard on. If it was up to me i would just Revitize everything and not deal with the Autocad, but at this time they dont want to spend the time on doing that so its up to me to figure out a way.
Tue, May 5, 2009 at 1:55:33 PM | Autocad Import Problems
4 Stars: 205 Votes
Try to see if the file has some layers OFF or FREEZE, Xref attach, i don't know, only seeing the file but.... sorry i can't help you more...
Autocad import problems
Thu, Jan 20, 2011 at 1:54:38 AM
Import topo surface from AutoCAD to Revit??
Thu, Oct 17, 2013 at 12:49:05 PM
Revit-Autocad Import/Cad Resolution problems
Tue, Aug 11, 2009 at 4:06:54 PM
import to revit from autocad
Sun, Mar 31, 2013 at 11:37:12 AM
REVIT 2015 autocad LINK and XREF problems
Tue, Nov 17, 2015 at 2:33:34 PM
Page generation time: 1.5895
