Forums >> Revit Building >> Technical Support >> Rotating Symbol geometry without rotating leabel
Mon, May 4, 2009 at 9:43:35 AM | Rotating Symbol geometry without rotating leabel
cadandbimbydx
If I create a 2D Symbol Family, I'd like to be able to rotate the symbol geometry, without rotating the text inside the geometry.
I have symbold that represent security cameras. And I need to be able to rotate the symbol to show the position of the camera.
Only thing I've been able to come up with is creating multiple family types for the different angles. But that doesnt allow me the freedom of rotating the camera at any angle I choose (short of creating 360 family types)
 Any ideas?
Mon, May 4, 2009 at 10:03:32 AM | Rotating Symbol geometry without rotating leabel
tim123
4 Stars: 19 Votes
You could create an angle instance parameter so that you can set in the angle of rotation once it is loaded.
Mon, May 4, 2009 at 10:12:33 AM | Rotating Symbol geometry without rotating leabel
cadandbimbydx
Thanks for the reply. I've tried that but it still rotates the text as well.
 How can I do this rotating the symbol without rotating the text.
Mon, May 4, 2009 at 11:11:45 AM | Rotating Symbol geometry without rotating leabel
You can set the text inside the family so that it is always "readable" and obeys your drafting rules or it can remain fixed to the symbol.
Mon, May 4, 2009 at 11:19:19 AM | Rotating Symbol geometry without rotating leabel
cadandbimbydx
ok thanks. i think that might work. it rotates so the text is always somewhat readable.
 i guess there is no way to make the text stay fixed?
Wed, May 6, 2009 at 5:37:20 AM | Rotating Symbol geometry without rotating leabel
tim123
4 Stars: 19 Votes
You should be able to do this with the generic annotation family.  Create a reference line and give it an angle instance parameter.  Create linework and lock it to the reference line.  Create the text.  The text will not rotate with the geometry when you load it into the project.
Wed, May 6, 2009 at 8:33:58 AM | Rotating Symbol geometry without rotating leabel
cadandbimbydx
that worked. thank you.
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Annotation Symbol Text - Keep Vertical?
Thu, Dec 15, 2011 at 3:23:42 PM
Photo symbol with non-rotating text
Mon, Jul 14, 2014 at 11:36:09 AM
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Page generation time: 0.1780
