Forums >> Revit Building >> Technical Support >> 2010 and vista 32-bit
Sun, May 3, 2009 at 10:55:31 PM | 2010 and vista 32-bit
Jaybo
4 Stars: 5 Votes
I installed 2010 and it will not work. Also Design review will not start either. I updated vista and my drivers and still will not work. The strange thing is when I right click the icon I can change the compatability to windows xp service pack 2. Then it will run, but I still cannot start new conceptual forms or even familys. I can only work in the project except when I load a family in it will crash Sad  So I have tried everything. When I install it to I need to select 32-bit ? Or will it automatically install what is right for your operating system. I noticed when it was installing its showed 86x or something like that what does this mean?
 Please help I want to use 2010 Sad
Mon, May 4, 2009 at 1:01:42 PM | 2010 and vista 32-bit
4 Stars: 205 Votes
Revit automatically recognise th OS you have and install the appropriate version, "Also Design review will not start either" I don't know what could be, did you try to uninstall and reinstall again????
Mon, May 4, 2009 at 1:23:30 PM | 2010 and vista 32-bit
Jaybo
4 Stars: 5 Votes
ok I tried again. It said 32-bit when first installing. Same problem and it is stressing me out. I tried the compatability to xp service pack 2 and then worked. But same problem.... this is a print screen of when I try to open a family or even new conceptual mass.
Mon, May 4, 2009 at 1:29:14 PM | 2010 and vista 32-bit
4 Stars: 205 Votes
There isn't such kind of that error in Autodesk: http://usa.autodesk.com/adsk/servlet/ps/search?la=en&rel=11764874&siteID=123112&catID=2334144&st=1&qt=revit+2010&linkID=9243099
I don't know what could be, I never see that....
Mon, May 4, 2009 at 1:32:28 PM | 2010 and vista 32-bit
Jaybo
4 Stars: 5 Votes
I just spoke to someone in chat and mabey it was the downloaded file
Mon, May 4, 2009 at 1:33:39 PM | 2010 and vista 32-bit
4 Stars: 205 Votes
You download the program via autodesk???
Mon, May 4, 2009 at 1:37:33 PM | 2010 and vista 32-bit
Jaybo
4 Stars: 5 Votes
yes the trial
Mon, May 4, 2009 at 1:38:53 PM | 2010 and vista 32-bit
4 Stars: 205 Votes
Well, I didn't see any problem with the file when i install or after....
Mon, May 4, 2009 at 1:45:30 PM | 2010 and vista 32-bit
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
My guess is your having an OS problem not a Revit problem. Is your Vista an upgrade from XP or is it the original OS for your machine?
Mon, May 4, 2009 at 3:08:06 PM | 2010 and vista 32-bit
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jaybo, well if you downloaded the Revit from Autodesk site, are you sure you also downloaded the .cab files?? ( I mean Family files, etc.)
Wed, May 6, 2009 at 7:59:02 AM | 2010 and vista 32-bit
#11
Jaybo
4 Stars: 5 Votes
My lap top is not even half a year old and is using vista 32 bit built in. Well no not all the family files just the templates. I dont see how this would effect it from not running. I might re install my operating system which really sucks if its not my system. To download another trial would take way too long so not sure what to try Sad
Thu, May 7, 2009 at 10:40:48 PM | 2010 and vista 32-bit
#12
Jaybo
4 Stars: 5 Votes
Ok I re installed my os and I installed revit 2010 although it still says 'revit section missing' when downloading the extra family files. Although this happened Revit 2010 now works Smile Glad I have a toshiba I only had to reformat 1 of my partitions hehe didnt take to long Smile yaya Im using the new conceptual modelling tool feels a lot more like sketch up and Im impressed witheverything so far.
HP DESIGN JET 1050C FOR VISTA 64 BIT
Fri, Apr 18, 2008 at 6:39:35 PM
R2010, Vista 64 bit...Crashes!!!
Tue, May 26, 2009 at 11:55:55 AM
64 bit revit, 64 bit vista and multi-cores... [ 1 2 ]
Sat, Apr 4, 2009 at 1:38:57 AM
29
Trouble Installing RAC 2010 x64
Thu, Oct 1, 2009 at 3:47:49 AM
Vista 64-bit Memory Query
Wed, Nov 17, 2010 at 2:01:25 PM
Page generation time: 0.9898
