Forums >> Revit Building >> Technical Support >> loaded families not visible in type selector
Sun, May 3, 2009 at 10:43:19 AM | loaded families not visible in type selector
jprado
downloaded doors family library from autodesk, loaded some doors into project, but they are not visible in the type selector.  i remember reading this in another thread but can't locate it.  any help would be great.  thanks!
Sun, May 3, 2009 at 11:24:59 AM | loaded families not visible in type selector
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jprado, you can verify if your doors are loaded in the Project Browser-->Families category, if so, just drag and drop to your mode (see image).
Edited on: Sun, May 3, 2009 at 11:27:12 AM
Sun, May 3, 2009 at 12:09:47 PM | loaded families not visible in type selector
jprado
thanks, but revit says the family is loaded but not in use, even though it does not appear in type selector or project browser.  see image
Sun, May 3, 2009 at 12:37:40 PM | loaded families not visible in type selector
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jprado, I downloaded the same elevator door you have just to try, you can find it in the Project Browser-->Families-->Specialty Equipment, just drag and drop....
Edited on: Sun, May 3, 2009 at 12:59:51 PM
Sun, May 3, 2009 at 1:30:04 PM | loaded families not visible in type selector
jprado
Thanks eland73, that makes a lot of sense.
Families loaded, but not visible.
Mon, Oct 25, 2021 at 7:08:22 PM
Performance lag with Type Selector
Fri, Feb 4, 2011 at 9:26:07 AM
TYPE SELECTOR for ramps and stairs
Thu, May 3, 2007 at 2:46:53 AM
FAMILY APPEARING IN TYPE SELECTOR
Sun, Apr 28, 2013 at 7:36:29 AM
Type Selector problems
Wed, Apr 10, 2013 at 6:35:58 AM
Page generation time: 2.8914
