Forums >> Revit Building >> Technical Support >> 3D Sections
Sun, May 3, 2009 at 7:30:56 AM | 3D Sections
Tim130
Is it possible to make 3D cross sectional view of the building which has been deisgned and then render these?
 I am using Revit 2009 version.
Thanks
Sun, May 3, 2009 at 7:57:52 AM | 3D Sections
tim123
4 Stars: 19 Votes
Certainly.  Switch on the section box in the view properties.  You can then drag this to cut the building how you wish.
Sun, May 3, 2009 at 7:58:01 AM | 3D Sections
4 Stars: 205 Votes
You have the Section Box in that view (perspective, plan, section...), use them to cut where you want then render...
window cills making walls disappear in sections
Tue, Feb 20, 2018 at 6:53:34 PM
view names in building sections are missing
Wed, Apr 2, 2008 at 6:19:24 AM
Easy way to turn off all but specific sections?
Thu, Jan 21, 2010 at 1:59:00 PM
Create Section lines to place sections separately under project browser
Mon, Sep 10, 2007 at 8:15:49 PM
Colour fills on sections? Revit 2008.
Tue, Feb 10, 2009 at 8:32:39 AM
Page generation time: 0.7607
