Forums >> Revit Building >> Technical Support >> PDF conversion
Sun, May 3, 2009 at 2:50:36 AM | PDF conversion
fireman3101
Ive got some dimensions in PDF format that i need to get into Revit, how do i do this? any help?
Sun, May 3, 2009 at 6:29:32 AM | PDF conversion
4 Stars: 205 Votes
And you want get into in Revit like what format????
Sun, May 3, 2009 at 11:41:22 AM | PDF conversion
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi fireman3101, one way could be to convert that file to a .dwg type file (you have to have a pdf to dwg converter to do that), then import it into your Revit file....
Sun, May 3, 2009 at 6:23:20 PM | PDF conversion
fireman3101
nice. can you recomend a converer cuz the one i found converts it to some file type that dosent open in revit
Sun, May 3, 2009 at 7:09:59 PM | PDF conversion
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi fireman 3101, try here:    http://www.autodwg.com/pdf-to-dwg-converter/
....the one i found converts it to some file type that dosent open in revit.....Most of these converters save the new files as .dxf, so what you have to do is to open your file in AutoCAD and save it as .dwg.Then you have to IMPORT that .dwg 'cause you can't open .dwg files in Revit.
.txt Conversion to .pdf
Wed, Feb 8, 2012 at 3:43:28 AM
How to set custom unit conversion value
Thu, Jul 17, 2014 at 5:27:32 AM
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND??
Thu, Nov 4, 2010 at 9:43:22 AM
PDF File Names
Thu, Apr 7, 2011 at 8:37:37 AM
pdf print
Thu, Sep 25, 2014 at 6:04:04 PM
Page generation time: 5.2172
